Ok here's the score, my laptop is a dell XPS 1730m, it has two 512mb 8800m GTX graphics boards and an AGEIA PhysX Card. I read an article today that says that Nvidia have discontinued support for the Ageia card in their newer drivers so with newer drivers running it will instead move the Physx load onto one of the GPU's. Now I may be wrong but I see that as a problem performance wise.
I have the following options:
1: Use stock GFX drivers and stock Physx drivers
2: Use newest GFX drivers and stock Physx drivers
3: use newest GFX and Physx drivers
My plan was to run 3dmark06 for all 3 configs and stay with the highest scoring one, but I don't know if 3dmark06 supports Physx anyway, which benchmark should I use?
Also if the Physx isn't running on the PPU by newer drivers will it be moved onto a GPU (hurting SLi performance) or onto the CPU? thanks
