- 13 Jun 2016
- UK
So I am currently running Pi-Hole on a Raspberry Pi. Absolutely love it and when I get my home server up and running, might move it to a Debian container. Anyway, I digress - I am not able to get IP addresses to resolve to hostnames unless I actually edit the /etc/hosts file on my Pi. I am sure there must be a more elegant way of doing it!
So this image from my Pi-Hole web interface shows what I mean. I would like the local IP addresses to show their hostnames instead:
However localhost and vanguard resolve if I edit my Pi /etc/hosts file and then reboot:
According to the Pi-Hole web admin GUI, I should be able to achieve what I want by using conditional forwarding, which I have tried setting up as per the below image - 192.168.1.1 is by EdgeRouter:
But that doesn't work. Here are what I think are the relevant parts of my EdgeRouter setup. First is the DHCP setup - I'm using one DHCP server for eth1, called 'LAN1':
I've set the domain name to be LAN1 below, with DNS1 to be my Raspberry Pi's IP address:
And below you can see the static IP mappings for some of the devices:
And inside the DNS wizard on my EdgeRouter I've got the various hostnames setup, as I think the names under the DHCP server configuration are just a 'simple name' and not actually the network hostname...
I don't get why it doesn't work and have reached as far as I can go
Any ideas would be much appreciated and I've put it in the open source subforum as I'm hoping I'll get more help from here
TIA
TIA
