Pick of the pre-built machines?
26 Aug 2025
UK
Hi there,
It's been many years since I specced a gaming PC and a friend wants to get something for their kid. Up to £1000, ideally in stock or built to order, what's the best pick of the pre-built machines here?
I don't know what's a good graphics card anymore, or whether AMD offers better bang for buck these days... Any advice gratefully received!
Not easy to get a great spec for £1000. The ones with newer 16GB cards, like the 9060 XT or 5060 Ti (avoid the 8GB versions) tend to be well over £1000. Getting AM5 is also tricky.
What resolution is this for gaming at?
I'm not sure what a decent minimum for resolution is these days, but I guess maybe 1080p?
1080p is the minimum, yes and is typical for esports games that kids usually play.
1440p is a nicer experience (more immersive) for e.g. single player role playing games, but you'd need a strong graphics card, so I'd personally avoid a build with say.. a 4060, if that was my intention.
You could see what OCUK would charge to build this to order, I'd at the least try to spring more for a better case, another £25-30 would be enough.
The only thing you'd need to do would be install Windows yourself, but that's easy enough via USB and keys can be had for £10-20.
My basket at OcUK:
Total: £797.88 (includes delivery: £11.98)​
We happen to have a 4K monitor (Samsung F32TU870VP) but don't expect to be gaming at 4K!
