Does SkyQ offer HDR? Just because it's UHD it doesn't mean it's HDR. Try The Grand Tour on Amazon, make sure it's the UHD version. The TV should go into HDR mode. In the unlikely event that it doesn't, you might have a problem.
will the panels and electronics be 2017 ?As the name implies, A7 will be LG’s most affordable 2017 OLED TV. To hit the lower price point, LG has implemented 1080p HD resolution, excluded support for HDR, and equipped the TV with an old version of webOS, namely webOS 2.0 that was introduced in 2015.
On top of that, HDR10 is an open-source format (no licensing fees for using it or advertising it), which allows manufacturers and studios to use it as they see fit without any consensus on how the content should be displayed.
What's the low down on the B6 vs the B7?
B6 is getting mighty tempting....suspect stocks won't be around long though.
What's the difference between the B6D and B6V?
LG rejuvinating 1080p market
interesting marketting strategy, are 2k1Kpanels much cheaper to produce than 4k.
or they want to preserve the profits from their 4k sets, but also take away some of the sub £1000 market, with a product with better PQ and
well adapted to many homes where acceptable screen size and viewing distance mean 4K questionable.
Am I the only one running deblur 1, dejudder 1? I found the panning shots in Sicario were smoother deblur 1 vs deblur 10 more stutter
According to this post a a few pages back the main difference between the 2016 and newer 2017 models are
- better handling of details in dark/black areas
- better handling of motion
- reduced ABL
- lower input lag across the board
Not had any issues with motion and input lag is fine on my B6. Don't think any of them points are worth the extra £1k.
The LG OLED55B7V has dropped another £100 on Richer to £2399. Think I'll bite at £2000.
