Yeah, I'm resigned to continue building my own but am fed up trying to put together a home system with more than 16GB. I've spent weeks trying to find the right combination of kit which will tick all the boxes for a beefy server which will last a good while as well.
Needs to be able to run 24GB
A tri-channel X58 mobo with all 24GB loaded can only run the memory at 1066 or 800. I need to find out if it's possible/worth it to underclock 1333MHz DDR3 down to 1066
Needs to support VT-d as well as VT-x
Trying to find out for absolute certain if the mobo and CPU must both support VT-d has been a challenge. The Socket 1366 i7-9xxx CPUs that would go into the x58 boards do not support VT-d if you check on Intel's site. Other sources have said only the mobo needs to support it.
Need a hardware RAID 10 card which will run under ESX 4.1
Another bloody nightmare. The Whitebox HCL are all out of date and need revising for ESXi 4.1
Need at least 2 GBe cards.
The only bit I've got sorted!
I can't hang on till the end of the year for the purported quad-channel DDR3 SB chipsets to arrive but am bashing my head against the wall currently. I can pick up an IBM X3655 with dual Opterons and 32GB for £200 which is the reason for this post.
