Picture of an Arctic Cooling Freezer 64 Pro in there case.
23 Oct 2006
Newcastle, The Toon
Stated int he name...has anyone got a picture of a Arctic Cooling Freezer 64 Pro in there case? I want to see exactly how big it is and what it looks like installed.
thanks Ryan
Next steps will probably be a matt black paint on the inside along with braiding for the PSU (or a new PSU).
@OP with the stock fan isntalled they are about 3cm lower than mine so they should fit in pretty much any case apart from SFFs.
heres my artic cooler 64
what are these HSF's like for the AMD's ? are thay as good as the freezer 7 prios are for intels ?
just im thinking of buildign a cheap 939 setup.
Rick
Correct me if i am wrong but surely you have your rear case fan and CPU Cooler fan working against each other :confused:
Your CPU cooler fan is drawing it towards the front of the case and the case fan is extracing it in the opposite direction.
I have mine the other way round so that my rear 120 case fan sucks in the same direction as my CPU cooler increasing the draft and exhausting it out the rear.
:cool:
To be honest i can't remember.
The only reason i brought it up was when i installed mine i wasn't that impressed with the cooling. Having another look i realised i had put it on the wrong way :o :p .
I can't honestly remember which way round it is now i just know i sorted it to work with my rear 120 and now the temps are Superb.
I just didn't want anyone making the same STUPID mistake i made :o
Thanks for putting me right though i wouldn't want anyone to be sent the wrong way.
it does push the air over the heatsink and out the rear. tbh the fan is not moving anyway as my temps at idle running sit about 30C and the fan only coms on at 35C so its nice and quiet till i start gaming.
