- 7 Mar 2005
- LU7
Trying to get Pidgin 2.5.0 working so I can see how far it has come and if it is now a proper challenger to WLM. One problem with previous versions of Pidgin was the lack of MSN smilies and I could never get any smilie packs to work. Pidgin 2.5.0 now has MSN smilies.
However when I install and run Pidgin I get an error message saying "Unable to connect". Any ideas what is going wrong and how to fix it?
So your IP is 192.168.0.2? In your last post you said the port was forwarded to 192.168.0.1 and that this was your IP - big distinction. Either way, disable the rule and allow UPnP to do its thing. BTW you will find it much (much) better to change the advertisement time of UPnP to about 1 minute instead of the default 30. A router reboot after changing these settings wouldn't hurt either
Rebooting the router wouldn't be a clever idea on my part.
Fun but not clever.
