Pigs trotters
22 Jan 2004
I've just bought half a Tamworth pig from a farmer and there are two trotters in there and I havent a clue what to do with them.
Anyone here ever cooked them and can they be tasty?
cheers
Ferret
that recipe looks nice but has very expensive ingredients I'm not sure i want to experiment with pigs trotters.
Maybe I'll go retro and make a terrine.
Out of interest anyone here ever cooked trotters?
  • 8 fresh pigs' feet (not pickled!), ideally the front ones
  • 2 large onions
  • 2 large carrots
  • 2 bay leaves
  • Bunch of parsley
  • 12 peppercorns
  • 1 egg, beaten
  • 125g / 4 ounces dried breadcrumbs
  • Bacon fat or oil for roasting
  • Parsley to garnish
Wash the pigs' feet well. Sometimes they have some bristles left on them: you can either scrape these off, or leave them where they are -- cooking will soften them (or even dissolve them), and you can scrape them off afterwards.
If you simply boil them naked, they may fall apart: so it makes for a much more attractive final result (and crubeens that are a lot easier to handle) if you wrap them in cheesecloth first. As in the picture, for each pig's trotter, cut a piece of cheesecloth that's a roughly couple of feet long and eighteen inches wide. Place the trotter on the piece of cheesecloth and roll it up; then twist the ends until they're cordlike, bring them together at the middle of the trotter, and tie them together.
When the trotters are wrapped, put them into a large pot with the onions, carrots, bay leaves, parsley and peppercorns: cover with cold water and bring to a boil. Cover, reduce the heat, and simmer gently for 2-3 hours, until the meat is tender.
Remove the trotters carefully from the cooking liquid, and allow them to drain in a colander, still wrapped, until they're easy to handle. Then unwrap them carefully. (They may try to fall apart on you if they're tender enough. This is a good sign, but can make things exciting, so be careful.) If necessary, pat the trotters dry with paper towels / kitchen paper.
Have the beaten egg and breadcrumbs ready in separate dishes. (We used cornflake crumbs for our example: they worked very well.) Dip each crubeen in the beaten egg, then roll in breadcrumbs. Repeat is you desire an extra thick crust.
Preheat the oven to 220C / 450F. Heat the bacon fat or oil in a shallow roasting dish. Place the trotters in the dish and spoon the fat or oil over them. Roast in the oven for about 30 minutes until crisp and golden, basting again with the fat about halfway through the cooking time. When finished roasting, remove each crubeen or pair of crubeens to a separate plate. Garnish with the spare parsley and serve immediately with soda bread and stout.
- Boil trotters
- Serve trotters with salt and pepper
- Chew on trotters in order to preserve the delightful, lingering taste
If you only have 2 I would suggest adding them to your stock pot next time you make stock. The natural gelatines will help your stock set and they add a good flavour. The meat could probably be recovered for use in a coarse terrine or pate too.
Why would you want your stock to set?
Have to say my family always uses the trotters as dog food. If you want to have a go at them yourself though, I'd suggets boiling them in some manner.
Good on you for supporting a local farmer direct though!
Well, I boiled the trotters for an hour then finished them in the oven with garlic, honey and chilli. They were pretty bad to be honest, just gristle bone and cartilage...yum.
Ahleckz, i ordered online from http://www.paddock.fm as I'd tried tamworth pork before from a farmers market and wanted to order a load in.
The pork is delicious, apart from the trotters of course
Ferret
didnt realise you could eat the trotters. used to get them for free from the butchers a few years ago. only fed them to the dogs though.
Makes me want to buy a pig. mmm think of all the bacon and pork.
Traditionally Bacon and Pork can't really be got from the same pig with any satisfaction. A Baconer is traditionally an older pig than a pork pig. I've made bacon from pork pig and it's not as good as from a baconer, for a start the rashers are smaller. Modern industrial farming may have changed this but I'm not sure.
