Posting this in here as it doesn't seem to be getting noticed. Mod can lock/delete the one in 8 Pack's section.
New to OC'ing and recently got my 955 to 3.8Ghz on 1.425v. Prime stable at <50. (as far as I can tell)
The above is with everything set to "normal" + x19 multi.
I can get prime to run for a few mins @ 4Ghz on 1.5v but then bluescreen. Can I assume from this that I'm close to stable?
Would appreciate some help on getting a solid 4Ghz, is it time to start changing more settings? People recommend upping the NB for best performance.
I attempted to change FSB and NB slightly whilst leaving everything else the same. The former gave bluescreen and NB changes cause "fatal errors" on some cores in prime.
Thanks
Thanks
