Pin Connection.
14 Sep 2009
Northumberland
I know it might sound stupid, but will the pin connectors on this fan be like the 6+2Pci-E ones?
Becasue I would like to have two of THESE as intake, and control my fans with THIS.
Would this setup work? + For the curious ones, my case is a Fractal R2 :)
Yes they can be used on a fan controller, just like they can be used on a normal 3pin mobo header, you just lose the PWM function, as that connecter has nothing to connect too.
