Pininfarina cases at OCUK
24 Dec 2004
Knowle, Solihull, UK
Hi
Just noticed that OCUK are now selling Pininfarina cases (link)
What do people think?
I quite like the design, although the bulge might be a little large on the top
i don't like the idea of 3x80mm cooling fans..and the N.W. Weight 13.50 K.G
G.W. Weight 14.50 K.G
SP-ATX-PALU/B Pininfarina
Dimensions 495x200x450mm (L x W x H)
Material Aluminum Alloy Bezel & Metal SECC Galvanized Steel Chassis
Material thickness Aluminum 6.0mm | SECC 1.0mm
Color Pitch Black
Mainboard Extend ATX & Micro ATX
5.25 Bays 3 visible
3.5 Bays 2 visible ~ 4 hidden
Bracket slots 7
Cooling 3x 80x80x25mm fans (rear included, right included, left not included) 1x 120x120x25mm (front included)
External Connections USB 2.0 x 2 | MIC x 1 | Earphone jack x 1 |
IEEE 1394 x 1
Features Lightweight aluminum & Durable metal frame. Italian Stylish design. Front USB, IEEE1394 & Sound connections. full screen, radiation protected. Side panel access, screw free installation. Optimized internal space design for Highly-efficient airflow.
Packaging 522x260x517mm (L x W x H)
6.0mm Aluminium? That's thick! But only the front panel is alloy, the rest is steel, hence the weight.
But I like the looks of it and it could be very practical. 22db 120mm Fan/20db 80mm fans should be nice and quiet too.
Quite pricey though.
The side panel looks a bit busy.
Seems a little overpriced, but I must get my hands on one of these. Look like they could be quite something in the flesh.
suicidle_tramp said:
I think it looks nice aesthetically, but 80mm fans? I thought todays cases came with 120mm as standard, or is that me being too believing?
80mm is still perfectly fine in a modern day case, although only used to suppliment a high end system in this day and age, so ideally only if your running SLI as a side blowhole etc.
80mm as the core of a modern designed case is quite lazy.
At least theres space for a 120mm fan on the side... I just taped up and marked out the lines for making one on my Super Lanboy :p
Dual core pentium D's get warm :)
Might try that on mine some time ;)
Seen some new pictures up on somewhere I can not link, it does not look that special in user pictures, got my hopes up aswell :(
Yewen could not wait to get his grubby little hands on that :p but it seems a change of mind has occured lol.
I think the looks leave a little to be desired hehe. :confused:
