Permabanned
- 28 Dec 2009
- london
I was getting annoyed with the windows 7 start menu, when the shortcut has one of those extender menus or task menus. Then clicking on the pinned items sometimes did not open the program and sometimes i had to click on it a few times and it would open twice and just be annoying.
So does anyone know how to disable the windows 7 start menu pinned shortcuts from extending in to jump lists and task lists. I can disable jump list but the menu still there.
I fixed it by making a bat file and shortcut
for opera, i created a bat file in the opera program files folder called mssucks.bat then i created a shortcut to the bat file and also put it in the opera directory.
contents of the bat file:
Then set the icon of the shortcut to the opera.exe and drag the short cut in to the pinned items area. The only downside is that there is a quick flash of a dos window.
PHP:
start /B /D "C:\Program Files (x86)\Opera" opera.exe
