Pioneer Kuro switches it's self off
25 May 2011
This is my parents TV that I gave to them last year.. they have said the TV switches it's self off at random points then auto comes back on again.
Heat or PSU issue?
Worth me taking the back off and cleaning?
Seems to be a known issue from searching
Heat or PSU issue?
Both. Too much crud in there. Back off, vac in and give it a damn good clean. Make shure you give the PSU a proper going over as well......................job done.
Also check if the auto off is enabled..
You find in the menu under "Power Control" Tab
No Operation = Enabled
Turns power off automatically when when no operation is done for 3 hours
