- 4 Apr 2006
- Norwich
hi all brought these two things and they arrived today.
http://www.overclockers.co.uk/showp...unted Watercooling Kit (Socket 939/AM2/LGA775)
and
http://www.overclockers.co.uk/showp...oupid=701&catid=193&subcat=1048&name=XSPC 3/8"%20High%20Flexibility%20PVC%20Tubing%20-%201m
when i got it all out the pipe dimiter of the tubing i brought seems larger than the one in the box. it only seems fractional but the fittings are less snug in the pipe than the supplied ones, once i have the tightening rings on will it be ok? or is the pipe i have brought likely to leak?
thanks loki
and
thanks loki
