This is kind of a follow up to a previous thread I made. I was having the problem that videos are stretched when played on my widescreen TV. There is an option in media player 11 that sounds like it should fix it, but it does nothing.
If you go to tools->options->devices->display->properties there is a slide bar to change the pixel aspect ratio. I have played around with this but nothing I do has any effect on the image. Does this option work for anyone else? It would be the perfect solution to my problem if only it did anything.
