Pizza stone
23 Mar 2005
So im making calzone tonight and popped it in the oven on my pizza stone from pampered chef.
After 2 minutes I hear a loud bang and find the stone has shattered. Can someone recommend a new one? I take it these done like getting hot.
you didnt shove it cold into a preheated oven? its suposed to be in the oven when you turn it on and left to cool down slowly inside the oven as quick temprature change can break them
Something no one in this house does :p
In they go with the pizza on, out they go. Never had any problems :) We have 2 mind you
The whole point is the stone should be scalding hot, something it isn't if you are building the pizza on it!
Try using a flat baking sheet which is dusted with semolina / flour as a peel and slide your pizza onto the stone in the oven. :)
This. It's fairly pointless using one otherwise.
