Pl was fine but after a reboot it tries to beep every 3 seconds?
17 Jul 2015
PC was fine but after a reboot it tries to beep every 3 seconds?
The pc won't boot, it was fine then I tried to shut down and restart and it just started making a noise from the internal speaker (like it's trying to beep but can't quite do it) every 3 seconds. The screen stays off.*
I held the power button to shut it down.*
I tried to start it again and it went in to a continuous boot loop. I switched it off when It was off during the boot.*
I removed a stick of ram and it booted right up. I though sorted till I did a restart and it just started to beep every 3 seconds again! I tried different combos with the ram and sometimes it will boot and other times it will just go straight in to the 3 second beep. If it does work as soon as you shut it down and restart it happens again.
