- 25 Oct 2005
I've just fixed a problem with my printer, thought I'd share it here as it was an obvious fix that took me a while to think of.
I have a Creality CR-6 SE, it had generally been a good printer. I upgraded to an all metal hot end so that i can print ABS in the future. All worked well until the prints started failing, recently i havent been able to print anything; the print would start OK and then after the base layers were down it would all peel off into a sticky mess. Things would get worse no matter what I tried with temperatures, different slicers.
I don't really know much about 3d printing, so if it doesnt work I get a bit stuck. As nothing was fixing it I was getting worried that I may not be able to sort it. Eventually I looked at the nozzle and found that the hot end was covered in resin; at some point a print must have failed and got resin everywhere. I stripped it down, cleaned everything out and hey presto it's printing nicely again!
Anyway, Tl;DR check your hot end if prints are starting OK, then getting pulled of the build plate! I'm guessing I should do some regular maintenance to stop any resin building up.
