Pla rate ny pc
1 Sep 2023
Staffordshire
Kind of new to pc building and I want a budget PC for light to medium gaming and mostly school work. This is what I've chosen.
I'm kinda confused on the WiFi adapter is this somthing ill do myself or will it be built in for me?
If any one has a better budget pc in mind please feel free to say. My max budget is £900 to £1000
1 X OcUK Gaming Firefly Essential - Intel Core i5 11400F GeForce RTX 3050 Gamin - £987.02
SKU: FS-1DX-OG
1 x Kolink Nimbus RGB Midi Tower Case - Black
1 x Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
1 x Gainward GeForce RTX 3060 Ghost LHR 12GB GDDR6 PCI-Express Graphics Card
1 x WD Blue SN570 1TB SSD NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T3B0C)
1 x ASUS PCE-AX58BT Dual-Band Wireless AX3000 (WiFi 6) Bluetooth 5.0 PCI-E Adapter
1 x Build Stock Microsoft Windows 11 Home Advanced - Systems
that is old hardware, surprised they're even selling it anymore.
Sadly, it appears to be the best option. I did try, but all I ended up with was the same PC:
My basket at OcUK:
  • 1 x OcUK Gaming Dagger - Intel Core i3/i5 GeForce RTX Gaming PC (SKU: FS-080-OG) = £1,002.95
    • Case: 1 x Kolink Inspire Series K2 Plus ARGB Micro-ATX Case - Black Window
    • Processor: 1 x Build Stock Intel Core i5-11400F 2.60GHz (Rocket Lake) Socket LGA1200 Proce
    • Memory: 1 x Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
    • Graphics Card: 1 x Zotac GeForce RTX 3060 Twin Edge LHR 12GB GDDR6 PCI-Express Graphics Card
    • Primary Solid State Drive: 1 x WD Blue SN570 1TB SSD NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T3B0C)
    • WIFI USB: 1 x Asus AC53 Compact Nano USB AC Wireless Adaptor
    • Operating System: 1 x Build Stock Microsoft Windows 11 Home Advanced - Systems
Total: £1,010.94 (includes delivery: £7.99)​
Best alternative I could do, but over budget:
My basket at OcUK:
  • 1 x OcUK Gaming Kinetic R4 - AMD B450 Configurable Ryzen 5000 Series Gaming PC (SKU: FS-1DN-OG) = £1,059.94
    • Case: 1 x Kolink Citadel Micro-ATX Case - Black
    • Processor: 1 x AMD Ryzen 5 5600X Six Core 4.6GHz (Socket AM4) Processor - Retail
    • Graphics Card: 1 x Gigabyte GeForce RTX 3060 WindForce OC LHR 12GB GDDR6 PCI-Express Graphics Card
    • 2.5" Solid State Drive: 1 x Samsung 1TB 870 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-77E1T0B/EU)
    • USB WIFI: 1 x Asus AC53 Compact Nano USB AC Wireless Adaptor
Total: £1,067.93 (includes delivery: £7.99)​
You would need to get a monitor with a desktop. Do you have one at home or would that need to fit into the budget? If you need a monitor, would you consider a laptop like the ASUS TUF A15 for either £950 or £1000. The main difference is the GPU included (Nvidia 4050 or AMD 7600S) neither of which I am familiar with as they are mobile options. For you though, this may be an ideal compromise
I don't have a moniter at home.
The monitor is excluded from the budget. I'll most likely get a 24 inch 1080p monitor from overclockers or somewhere else once I do my research.
I was going to say i'm surprised you can't squeeze a recent gen DDR5 in there, but that might involve other retailers which we can't discuss.
Plus I suppose you're adding a windows licence. Depending on circumstance you could save money and go Linux if you have the patience to get it working.
It'll likely be quicker to build your own, can build it in an afternoon, though since this is your first try, maybe not that fast.
What's your opinion in 1080p 27 inch.
I hadn't seen a 24 inch monitor in person but I'm seeing it right now and it's quite small for my liking.
I'm right now thinking of getting a 27 inch 1080p monitor
Probably best to start a new thread in the monitor forum, with your budget/requirements, I'm one of the worst people on the forum to ask about monitors :D
For what it is worth, I think 27" is too large for 1080p, so I'd be going 1440p. But, 1440p is also more demanding on the graphics card.
I have no idea if these are good monitors, but the resolution and the size seems better.
My basket at OcUK:
Total: £236.96 (includes delivery: £11.98)​
