placement of Edifier R1900 TII
8 Apr 2011
Hi all I have a pair of r1900 tIIs and have no room on my desk for them so was wondering where to put them? Does anyone know if there are any shelves or stands that hold these?
Just get some speaker brackets and fix them to the wall, ensuring that the brackets can take the weight.
I found when trying my Bheringer ms20's on the wall with brackets, they stuck out a hell of a lot, and that was just with the depth of the speakers, with the Edifier R1900 TII, don't they have fins on the back ? Personally I have mine on each corner of the desk, pointing in at an angle, so the sound is directed to each side perfectly. That's the worst thing about active studio monitors,is the depth with the cables, fins, and generally deeper than the norm, they tend to stick out more than regular desktop speakers.
I have my 1600's on the back corners of the desk pointing in slightly too. It leaves a few inches behind for the ports to work. Problem is though if there's no room on the desk then the wall is the only other option - unless the OP gets a bigger desk of course (probably the best solution)
