Planned watercooled build pipe route
29 Dec 2014
The "North"
Hi, I'm planning to do a watercooled built with the CPU and GPU in the Phanteks Enthoo Luxe case and I'm wondering if the pipe route I've created in MS paint is a good rough guide. Since I don't have the case I am just speculating so any help is appreciated :D
The tubing will be acrylic and the reason why half is green is that it will be hidden.
What radiators are you using?
XSPC radiators, a cross flow for the 360mm top and regular 240mm for the bottom. I may also add a 120mm to the side just to fill the case.
If anyone recommends a better radiator I may switch. (I haven't really seen a massive difference between the manufacturers radiators)
Rad choice is fine. Tubing run looks clean too.
I wouldn't bother adding another 120mm rad as it would require more tubing fittings and space plus won't help much.
Ahh, I will leave that then. I'll probably add some airflow fans to help cool the components :)
