Hi guys
As the title suggests I am planning to take the plunge and build my own pc later this autumn. Having read up on the forums (so much knowledge and good advice her by the way)
I am currently looking at a build around an intel i5 3570k with one of the 7850 cards inside, a suitable motherboard and 8gig of ram to utilise 64 bit windows seven (already owned). Most of my current system undoubtedly needs an upgrade but I would really appreciate some advice on a couple of components that I am wondering if I can keep?
I have a 500w OCZ sxs2 psu. Will this be ok to run the 7850 and i5? I will hopefully have an ssd in the new system and a hdd. I have no immediate plans to overclock although I may in the future
I have a couple of 500g hard drives, a barracuda 7200 and a Samsung 7200. Both appear to have 16mb cache. They would be used predominantly for data, photos etc as I hope to have an ssd big enough to install windows, some games and ms office would these be ok? My understanding is they wouldn't bottle neck it if the ssd is the boot drive? Or would I better to buy a new one?
I have a Samsung DVD rewriter which I am pretty sure is sata (model sh-s203D). I don't really use it much other than for installing and importing data. I am guessing I could reuse this?
My main gaming currently is on wow which I really want to play on high or better settings all round. I play on a 22 inch at 1650x1080 which i won't be changing. I would like to play some bf3 etc on good ish settings but my main focus is to build something which will not be outdated to quickly ( I normally upgrade every 4-5 years with a gpu upgrade after 2 years)
I would really appreciate any advice on those components that may be reusable, particularly the psu as 60 quid saved there is another 60 quid on a bigger ssd. I will be asking advice on particular components in the next month or so for a build in November when I have the money to buy the components.
Thanks
Chris
Thanks
Chris
