Ok so, I'm planning my first build and just need some suggestions for hardware. System will be used primarily for streaming, gaming, P2P downloading etc.. The usual stuff! Anyway, so far I have picked out some components that I'd just like to run by you all to make sure I'm getting the best bang for buck or if there is anything else you would recommend instead of what I'm about to list. So...
CPU: https://www.overclockers.co.uk/showproduct.php?prodid=CP-539-IN&groupid=701&catid=6&subcat=567
BOARD: https://www.overclockers.co.uk/showproduct.php?prodid=MB-491-GI
RAM: https://www.overclockers.co.uk/showproduct.php?prodid=MY-178-KS&groupid=701&catid=8&subcat=1387
GPU: https://www.overclockers.co.uk/showproduct.php?prodid=GX-344-AS&groupid=701&catid=1914
SSD: https://www.overclockers.co.uk/showproduct.php?prodid=HD-055-CR&groupid=701&catid=2104&subcat=2394
HDD: https://www.overclockers.co.uk/showproduct.php?prodid=HD-257-SE&groupid=701&catid=14&subcat=1279
OPTICAL DRIVE: https://www.overclockers.co.uk/showproduct.php?prodid=CD-155-SA&groupid=701&catid=10
That's my list so far, just need help choosing a PSU (Preferably modular) A case (With good cable management) and cooling.
Any suggestions on hardware would be great ? Ideally I'd like to get a bit cheaper but the same level of spec. Also any tips tricks or secrets for my first build will be appreciated muchly.
