Hey all
First real post here... been lurking for a while, but thought I'd actually join and start joining it with discussions here
I'm currently planning out my new PC build and want to go PETG tube liquid cooling for it... was hoping I could get some advice here
My current plan looks like this... I'll be using the Be Quiet 900 Pro in white for the build, in it's inverted layout... hence planning every little detail out first as it'll be quite a unique look when it's done
here's my plan so far...
So the loop will be going anti-clockwise... Res -> Pump -> CPU / GPU dual run -> Radiators -> Res
I'll add a drain port / valve between the res and the pump under the PSU shroud for maintenance... and possibly a fill port with tube leading up to the top of the case from the res, depending on measurements once I've fitted the top radiator in place.
Does this look good? Any problems or recommendations? Would love to hear from people more experienced at this than me.
Thanks in advance
M
Thanks in advance
M
