Hi there,
I have a Panasonic Viera TX-P42X10 plasma and bought a wall mounted corner bracket from ebay and received it today, so I put it up and I was horrifed because the arm joint was bent, literally, check these images out
Bent arm joint
so it looked like this without the tv attached
wall mounted corner tv bracket
Can anyone recommend a bang for buck bracket which will hold my 42" plasma which is not going to cost me the earth?
Thanks in advance
Bent arm joint
Thanks in advance
