plasma calibration
Caporegime
1 Jun 2006
Notts
hi can anyone direct me to either easiest way to get plasma calibrated through either settings programs or dvd cheers
i had it looking pretty decent then one of kids changed it :p cant seem to get it same :(
Probably best searching avforums for your particular model and seeing what users come up with (Look fo D65 spec) and setting brightness/contrast yourself from the AVSForum disc. Unless you go buy a spyder or similar there's not much else you can do.
HDTVTest sometimes post up settings aswell, but its whether they've reviewed your tv or not.
well just found settings for my plasma on avforums :cool:
as i was changing i was like hmm not sure but now changed all settings and the difference is very clear :D thanks for help
