120cm x 20cm. It's a solid wood shelf. The brackets I have can hold 10kg each.how big a shelf and what are you planning on putting on said shelf?
Fischer duopower red (6mm drill bit) plugs and a 4 or 5mm screw are my standard go to for most applications that aren't extremely high load eg cantilevered tvs
Ive been thru a box of 100 since a year ago
fischer 555006 DUOPOWER Wall Plug, Red/Grey, 6x30, Set of 100 Pieces https://amzn.eu/d/5Lp2za7
Its designed for dot n dab plasterboard, not a true plasterboard fixing as all the load is transferred into the solid wall, same with rigifix which I prefer.When I was looking at mounting the TV on a solid brick wall, I did come across something called Corefix that's designed for plasterboard.
I've switched to these now myself after using metal inserts and those Screwfix ones that require a special drill bit previously.Fischer duopower red (6mm drill bit) plugs and a 4 or 5mm screw are my standard go to for most applications that aren't extremely high load eg cantilevered tvs
This is why I'm terrible at DIY, as I would have used corefix without realising it was for dot n dab.Its designed for dot n dab plasterboard, not a true plasterboard fixing as all the load is transferred into the solid wall, same with rigifix which I prefer.
