Plastering finish
  • Thread starter Thread starter DiG
  • Start date Start date
DiG
DiG
16 Mar 2004
Hi,
I had my first go at skimming a wall last weekend, quite surprised at how well it went!
The majority of the wall is perfect and smooth, however there are a few areas that have very small holes in where I didn't apply enough pressure and a couple of others with larger patches that are a 1/2 mm deep
Does anyone know the best way of improving these areas? I don't want to have to do another whole coat, but if I just do the affected bit then it won't match with the other side?
Thanks
Gyproc easi fill, good for floating up the areas.
You're right you will notice the difference but if you wanted a perfect finish first you should have got a pro in :D
