Hi I have stripped all my wallpapers down recently I have decided against wallpapers or paper lining and will be using plastering my slightly iffy plasterboards or skimming I think its called.
I noticed gaps and tapes around all the corners of my walls since half the tapes came off, can I buy some plaster tape (fiber glass mesh type) and then use wicks multi finish plaster to give a top coat and then paint ?
I only ask since some youtube vids show one has to use a special plaster (mud?) with plastering tape to patch those corners and would like to avoid this if possible.
