- 5 Jul 2009
- DONcaster
Would it be posslbe to plastidip hard tubes or copper????
Just mask off the bit that sticks in the fitting first. EK-HDC fittings are 8mm seating depth for example, so mask off 7mm and spray away.
This won't work. You need to put the fitting further down the tube before you screw it in, and it won't slide over a layer of plastidip.
Wanting to do matt black tubes but hardline
Pretty sure the compression caps will fit over the paint though if you wanted... it's not like it's thick and they don't fit tight to the tube.
