Plastic pocket folder holes.
21 Nov 2006
Dublin
At the moment I have a lot of those plastic pockets and dividers in a two ring binder and already one divider has come torn out because the two rings are close to the middle and they move around a lot.
Now judging by the amount of holes going up the side I assume there are better binders that spread the rings out from the middle. I've been looking around and the best I can find is a 3 ring binder.
What the hell uses all the other holes!? Is there a special name for binders that will use them?
Can't even find a 5 ring binder :o
Just looking to evenly distribute the weight across as many as possible so stuff doesn't get ripped out etc.
Talking about these btw :o
and what's up with those long holes :confused:
Yea, you want a 4 ring binder, far superior to the 2 rings. All the different holes are just for different designs of binders, not all to be used at the same time :p
And the US often uses 3-ring binders. And they use foolscap rather than A4 IIRC, so different 2- and 4-ring positions.
M
