24 Jun 2008 at 00:36 #1 Craig321 Craig321 Soldato Joined 2 May 2004 Posts 19,950 Hi, All I want is to play my 7.1 speakers through stereo, no surround sound. Is there any way? Thanks, Craig.
24 Jun 2008 at 00:39 #2 mofei1 mofei1 Associate Joined 14 Jul 2007 Posts 202 in vista audio options, set the speaker configuration to 2 speakers?
24 Jun 2008 at 00:42 #3 Craig321 Craig321 Soldato OP Joined 2 May 2004 Posts 19,950 There's the options of stereo, quadraphonic, 5.1 and 7.1. Unfortunately stereo literally does stereo... only uses 2 speakers
25 Jun 2008 at 12:36 #4 rubberduck rubberduck Permabanned Joined 8 Feb 2004 Posts 4,539 Craig321 said: There's the options of stereo, quadraphonic, 5.1 and 7.1. Unfortunately stereo literally does stereo... only uses 2 speakers Click to expand... What happens when you set it to 7.1?
25 Jun 2008 at 12:48 #5 Craig321 Craig321 Soldato OP Joined 2 May 2004 Posts 19,950 Music, and other audio plays out of the 2 front speakers. In the 7.1 test the left and right speakers don't work, everything else does. When an effect is applied to the sound every speaker works, but it sounds horrible because of that effect. Sorted now though. I'm using the sound drivers Vista automatically installs with the fill speakers option ticked.
