I believe VLC does it? Give it a try, report back![]()
I would look into using XBMC, it's the default program for HTPCs. Version 11 has bluray support.
Thanks for the replies
The drive is an LG GGC-H20L,LG website does not have any software listed for it.
It's so old it's probably discontinued now.
VLC does not appear to play Bluray's.
Alan
It doesn't play Blueray disks from its standard player, it will only play dvds.
You have to launch an external player like PowerDVD or TMT5 to play bluerays.
It will play back ripped blurays in file format like MKVs.
VLC are working on blueray but haven't finished it yet.
At the moment, afaik, there aren't any free solutions.
An option is using MakeMKV or similar to rip the disk to file then play it.
