Could someone explain my options here, basically my TV (2016 Panasonic Viera) does not have DTS support natively, but the media I have access to via DLNA (ethernet) is encoded with AC3 (current default) DTS, DTS-HD, True-HD etc depending on title in question. There is always AC3 available, and generally multiple other audio tracks of higher quality. I wanted to upgrade from the TV speakers - but knowing what path will enable DTS etc isn't clear;
Two considered options;
- I believe, that a DTS certified soundbar connected to the TV via ARC will not play DTS as the TV would only supply the AC3 track to the soundbar, and not provide the other audio tracks as alternatives.
- Some A/V receivers have DLNA clients built in, but it's unclear if they would allow the playback of video and streaming of video content to the TV, whilst they play back the HD audio.
In my case, I'm playing H.265 encoded video within MKV containers.
The current A\V model seems to miss the mark when it comes to streaming of high-quality content from network sources - which is clearly the future direction. Odd!
