Recently I've been playing a lot of minecraft on my GTX 580. I've allocated 5 gigs of ram to the Java 7, 64 bit (I got 16gigs ram). But the framerate is horrific. I am using the Hat Pack mods.
The game is far from smooth, frames can drop to 20 or less, with a stuttering every few seconds. I use MSI Afterburner to underclock the card because without it, a lot of games crashed. Using the hardware monitor in Afterburner I notice things which seem odd.
GPU usage is nearly 0, maybe moving up to 3/4% and that is just at the desktop. It is almost like my card is not being used to play minecraft. I've updated all drivers, using latest Nvidia. I've added javaw.exe to the Nvidia control panel to "force" it to use the GPU, but that doesn't work either, GPU usage still near zero.
I've just tried Arma 3 and that causes the GPU usage to hit 90/100 and the temp to rise. Im not sure if this is normal behaviour with minecraft of not. The game is nearly unplayable sometimes, closing it and re-opening can speed it up, but it is never smooth. I'm also not running any texture packs and Optifine made no difference, in fact I started to get graphical glitches, textures not appearing and being able to see through walls.
I've tweaked every settings I can to get more frames, nothing makes a difference, even going so far as to add commands in the launcher for Java, these are: -XX:MaxPermSize=128M -XX:+CMSIncrementalPacing -XX
arallelGCThreads=4 -XX:+AggressiveOpts -XX:+UseConcMarkSweepGC -XX:+UseParNewGC -XX:UseSSE=4
I'm even tempted to re-format my PC, as in some rare occasions that seems to fix issues only I have and no one else seems to experience.
arallelGCThreads=4 -XX:+AggressiveOpts -XX:+UseConcMarkSweepGC -XX:+UseParNewGC -XX:UseSSE=4 I'm even tempted to re-format my PC, as in some rare occasions that seems to fix issues only I have and no one else seems to experience.
