Playing MKV's. Audio skipping.
12 Dec 2005
I'm trying to play MKV's via VLC Media player. The video is perfectly smooth however the audio will go choppy every now and again.
What could be causing this?
Specs -
E6750 2.6Ghz
4GB DDR2
Nvidia GT430 1024MB
I have all of the latest drivers installed.
Cheers
Aye, that will be an issue with the video player - by default VLC runs without GPU-acceleration.
One option is to turn GPU acceleration on within VLC.
To do this go into Tools > Preferences > Inputs & Codecs tab > Codecs - then tick "Use GPU acceleration (experimental)" and then save. You may need to restart VLC for the new settings to come into effect.
However, after using VLC for a long time I would echo AtaRo and personally recommend MPC-HC (Media Player Classic - Home Cinema). This is a very nice, simple video player with good video quality and GPU acceleration set up by default.
If you are looking for the best quality codecs, I believe the Cyberlink PowerDVD codecs offer the highest video quality - though that software isn't free.
