- 27 Mar 2004
- Kent
I've just been forced to use wireless for my desktop computer at my university home (more on this later) and I'm finding the experience less than fun. I ended up buying a USB 802.11G adapter from Belkin. The speeds seem fine, downloading and connecting is fine.
However when I connect to online games, such as CS:S, BF2, or Arma2 the connection will occasionally "drop" for a second or so. My character will stop moving and a second or so later I'll show up somewhere else on the map. However my ping is usually low (I checked it in CS:S and had 5ms constant) but occasionally I'd get these "cuts". Is it because I'm on wireless? Is it because its a USB adapter (I don't have PCI slots to spare)?
I considered using a wire anyway since I have a long ethernet wire but no one seems to want me to lay a wire from my computer to the router in the living room (maybe 20m of cable, though the rooms are about 6 or so metres apart) because people might trip on it, which is understandable. Considering we're renting the house and the landlord probably isn't keen on me hammering wireclips into the walls, are there ways to tidily run a cable between rooms without leaving marks/traces?
