please advise
3 Feb 2006
not sure
hi all im gonna build a new pc for a m8 and could you lot look over me spec pleassseee its gonna be for light gameing etc:
Abit KN8 SLi nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-088-AB)
HyperTransport technology, which delivers a 2GHz effective system bus, is a high-speed, low latency, point-to-point link designed to increase the communication speed between integrated circuits in computers, servers, embedded systems, and networking and telecommunications equipment up to 48 times faster than some existing technologies.
- NVIDIA® NF4 SLi
- 2GHz HT
- Dual DDR 400
- NV SATAII RAID
- NV GbE
- NV Firewall
- 7.1 CH Audio
Price: £64.99 (£76.36 Including VAT at 17.5%)
AMD Athlon 64 3000+ Venice (Socket 939) - Retail (ADA3000BPBOX) (CP-117-AM)
AMD's Athlon 64 is the latest evolution in the desktop computer industry. With its revolutionary 64bit architecture this CPU is fully compatible with future 64 bit operating systems and offers blistering performance in current 32 bit applications. With AMD's new HyperTransport technology and a massive 512KB L2 cache. Venice core incorporates SSE3 technology into the Athlon 64 platform which increases performance levels.
This retail boxed product is supplied with an AMD heatsink and fan and has a 3 year warranty
Price: £38.99 (£45.81 Including VAT at 17.5%)
Corsair 1GB DDR XMS3200C2PT TwinX (2x512MB) CAS2 (MY-030-CS)
A matched pair of 512MB XMS3200C2 memory modules - 1GB total - ideal for dual DDR motherboards.
Price: £84.99 (£99.86 Including VAT at 17.5%)
OcUK GeForce 7300 GT 256MB GDDR3 HDTV/DVI (PCI-Express) - Retail (GX-040-OK)
NVIDIA® GeForce® 7300 graphics processing units (GPUs) allow you to experience the latest gaming effects without compromising performance. Boasting the 3D graphics features of today’s most advanced GPUs—including full support for Microsoft® DirectX® 9.0 Shader Model 3.0 and true high dynamic-range (HDR) lighting—GeForce 7300 GPUs also bring stunning, high definition video and superb picture clarity with minimal CPU usage with NVIDIA® PureVideo™ technology. For the performance and features you need to play the latest games and enjoy home-theater quality video, make sure your PC is equipped with a GeForce 7300 GPUs.
- GeForce 7300 GT Core running at 500MHz
- 256MB GDDR3 Extreme Memory running at 1200MHz
- 8 Pixel Pipelines
- SLI ready – Delivering upto 2x the performance
- Shader Model 3.0 Support
Price: £49.99 (£58.74 Including VAT at 17.5%)
Thermaltake VC2000BNS Mambo SuperMidi Tower - Black (CA-026-TT)
- Detachable front panel design
- Fits standard ATX motherboard
- Dual 120mm front and rear fan (front is optional)
- Tool-free for easy installation
- Dual USB2.0, Audio & speaker ports
- 430.3 x 200.2 x 502.2 mm
- Front (intake) 120x120x25 mm, 1300rpm, 17dBA (optional)
- Rear (exhaust) 120 x 120 x25 mm, 1300rpm, 17dBA
Price: £27.99 (£32.89 Including VAT at 17.5%)
Hiper HPU-4M580 Type R 580W ATX2.2 PSU - Black (CA-009-HP)
HPU-4M580 sets a class of its own from HIPER™ standard series. It’s really wallet friendly. It still offers the same power output specification of the award winning Type R- 580 series, the same amount of exTender™ just like Type R 580 series, not to mention the meshed body for excellent ventilation and it’s SLi certified.
- Supports ATX up to v2.2 & Intel BTX configuration.
- Complies with all Intel & AMD CPU specification requirement.
- Gold Plated connector, preventing rust & bad connection.
- High efficiency APFC (Active Power Factor Correction).
- Connects up to 4 SATA HDD + 8 other component devices.
- Dedicated PCI-E connector.
- EZ-Grip Molex connector.
- Includes P8 ATX12V connector for motherboards that supports dual core processors
Price: £44.99 (£52.86 Including VAT at 17.5%)
Western Digital Caviar Special Edition 80GB 800JD SATA-II 8MB Cache - OEM (HD-023-WD)
WD Caviar® SE Serial ATA hard drives have the features and capacities that are ideal for next-generation computers and low-end enterprise storage. Users benefit from a data transfer rate of 150 MB/s and an improved cabling that enables greater system design flexibility. Designers of enterprise storage systems and servers are increasingly using desktop-class, large-capacity SATA hard drives because of the advantages that the SATA interface provides.
- Rotational Speed: 7,200 RPM
- Capacity: 80GB
- Average Read Seek Time: 8.9 ms
- Buffer: 8MB
- Interface: Serial ATA
- 3 year manufacturer''s warranty
- Direct warranty and RMA service available here.
Recommended: Western Digital''s Serial ATA cable with SecureConnect™. provides a 500 percent stronger cable-to-drive connection than first-generation SATA hard drives and cables; for use with Western Digital SATA drives only.
OcUK Value Hanns-G HW191D 19" Widescreen LCD Monitor - Silver (MO-017-OK)
The OcUK Value HW191D has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 700:1 contrast ratio and excellent viewing angle there is no other TFT/LCD that can match the quality, value or performance.
- 1440 x 900 (WXGA) Optimum Resolution
- 16.2 Million Colours
- 700:1 Contrast Ratio
- 5ms Response Time
- 300 cd/m2 Brightness
- One DVI-D Input
- One Analogue Input
- 3 Years Manufacturer On-Site Warranty (Call Manufacturer direct on )
Price: £121.99 (£143.34 Including VAT at 17.5%)
Logitech Cordless Desktop EX-110 - Retail (KB-072-LG)
Have the clean, wire-free desk space you´ve dreamed about. The sleek Logitech® Cordless Desktop® EX 110 makes it incredibly easy and affordable to go cordless—in style. Quick and simple to set up, your keyboard and mouse will perform as fast and as reliably as any corded product.
- Fast, reliable 27 MHz wireless performance
- Media controls for music and video playback
- Advanced optical technology
- Programmable keys
- Adjust or mute music volume quickly
- Start your calculator onscreen with a single button
Price: £17.99 (£21.14 Including VAT at 17.5%)
Logitech S200 2.1 Black/Silver Stereo Speakers - OEM (SP-038-LG)
High quality subwoofer and satellite speakers deliver great sound quality. 5 watts per satellite combined with 20 watts sub-woofer. The 3 piece system is easily controlled with convenient volume, power and bass controls. Audio and microphone jacks provide the capabilities for private listening. The microphone and headset combination makes any PC communication easily accessible by simply adding a Logitech PC headset.
- 30W Speaker Set
- 5W per satellite
- 20W sub-woofer
- Power & volume controls
- Headphone jack
- Microphone Jack
- 3 Year limited guarantee
Price: £11.95 (£14.04 Including VAT at 17.5%)
Pioneer DVR-111BK 16x16 DVD±RW Dual Layer ReWriter - (Black) OEM (CD-041-PO)
The DVR-111BK offers writing support for Dual & Double Layer media types at 8X speed, along with 16X writing to DVD-R/+R, 5X writing to DVD-RAM, 6X writing to DVD-RW and 8X writing to +RW. The drive’s combined specifications deliver the one of the highest levels of all-round DVD-writing performance currently available.
- DVD+R: 16x, DVD-R: 16x
- DVD+R DL: 8x, DVD-R DL: 8x
- DVD+RW: 8x, DVD-RW: 6x
- DVD-ROM Read: 16x
- DVD-RAM: 5x
- CD-R Write: 40x
- CD-RW Write 32x
- CD Read: 40x
- Access time: 130ms
- Buffer Size: 2MB
Price: £20.99 (£24.66 Including VAT at 17.5%)
thanks all.
its gonna be for a friends kid for chrimbo he will use it for swat games etc cant real say atm.he needs the lot dont want to go to high so if you can spec me a good spec say for about 500 all in?.
CP-126-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£114.99 £114.99
MB-003-AK Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard (MB-003-AK)
£53.99 £53.99
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£139.99 £139.99
HD-079-SE Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE)
£51.99 £51.99
KB-051-MS Microsoft Wireless Optical Desktop 1000 Black - Retail (BV3-00007) (KB-051-MS)
£23.99 £23.99
Subtotal £384.95
VAT £67.37
Total £452.32
I have not specced a Graphics card because you can get a 6800 for around £40 from a well know competitor.....hence its all within your budget....as OCUK dont have them I cant include it...
U are better of with a 6800 then a 7300 dude...
I have specced all the bits you had a go at in your thread, apart from a case....
hi all soz to be a pain how about this for a complete setup? will it all work?.
cheers guys
MB-088-AB Abit KN8 SLi nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-088-AB) 1
£64.99 £64.99
CP-117-AM AMD Athlon 64 3000+ Venice (Socket 939) - Retail (ADA3000BPBOX) (CP-117-AM) 1
£38.99 £38.99
MY-030-CS Corsair 1GB DDR XMS3200C2PT TwinX (2x512MB) CAS2 (MY-030-CS) 1
£84.99 £84.99
GX-026-BG BFG 3DFuzion GeForce 7600 GS 256MB DDR2 TV-Out/DVI (PCI-Express) - Retail (GX-026-BG) 1
£64.99 £64.99
HD-023-WD Western Digital Caviar Special Edition 80GB 800JD SATA-II 8MB Cache - OEM (HD-023-WD) 1
£27.99 £27.99
CD-038-PO Pioneer DVR-111DBK 16x16 DVD±RW Dual Layer ReWriter - (Black) OEM (CD-038-PO) 1
£18.99 £18.99
CA-067-AN Antec NSK6500 Super Midi Tower Case - 430W PSU (CA 1
£58.99 £58.99
KB-072-LG Logitech Cordless Desktop EX-110 - Retail (KB-072-LG) 1
£17.99 £17.99
SP-038-LG Logitech S200 2.1 Black/Silver Stereo Speakers - OEM (SP-038-LG) 1
£11.95 £11.95
MO-016-OK OcUK Gamer Extreme 178GP 17" LCD Monitor - Black (MO-016-OK) 1
£99.99 £99.99
Subtotal £489.86
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £12.95
VAT £88.00
Total £590.81
why not get a conroe or an amd dual core? for the same money...
the parts you have chosen are not really value for money if you compare it to what you could get for the same amount of money...
hmmmm????
