Hi guys,
It has been a long time since i've built my own PC. I did it probably 10 years ago in my first year of uni and it was when the 2500 Bartons had just come out. Since then i've just used work pc's, my laptop I use for work and I use my consoles for gaming.
My current pc/laptop is a Dell 11z connected to a kb/mouse and 21 inch widescreen.
The time has come when I now have the itch for a super quick desktop to replace my work laptop with. I am now massively out of date with the current components, cores and pci-express type things and don't want to make a costly mistake so this is where you guys come in.
Must be:
Pretty quiet - my last PC was overclocked to the max etc and had a billion fans etc. This is a no go really. I don't mind a few but its main location at the moment is our lounge as I work from home and if its really noisy it will become a nuisance.
Fast - CPU/RAM etc must be plentiful and quick. It will primarily be a work PC but I will also use it for video editing and streaming my xbox etc. I only had a 1.6mb upload so I want it to be able to handle as much video encoding as possible so that it frees up some upload. I also do some graphic design etc. which is intensive. I run lots of applications from work and while my laptop (Dell 11z) is okay for this, I would like a bit more.
Storage - I have a small PC acting as a storage server but would like that built into here for convenience. Thinking at least 4TB. Is a solid state worthwhile for the OS and apps? Is the performance worth it?
Graphics - Not bothered about this at the moment but would like the option to stick something decent in, in the future if I like. I use my consoles for gaming.
Network - 10/100/1000 is fine for me and I have my own wireless card.
What do you suggest and thanks for helping. I don't want the VERY latest and greatest as I know you pay top dollar for this but whats the very best bang for buck at the moment?
Must be:
