please build me a WC setup
bump,
i need to cool mobo, cpu and 2 graphics cards
will the Swiftech H2O-220 Apex Ultima Watercooling Kit be able to do it, and is it really worth getting this kit, or better to build own one
You will need 2 loops. CPU on double rad on one and rest on triple in other.
1 x Watercool Heatkiller CPU LGA1366 Rev. 3 Copper
£58.99
2 x Laing DDC 18w Pump / Swiftech MCP355
- Aftermarket Top EK DDC X-Top
£134.74
2 x EK Multioption RES 150 Rev2
£51.98
1 x ThermoChill PA120.3 Radiator (15mm)
£64.99
1 x ThermoChill PA120.2 Radiator (15mm)-
£54.99
2 x EK-FC4890 CF - Acetal
£131.98
1 x EK-FB KIT GA X58 (Gigabyte) FB Kit -
£78.99
Sub-Total: £576.66
Then u need coolant, tubing, barbs and fans of your choice.
thanks for the reply bradley,
that surely looks expensive :P
so thats the waterblock that fully covers the graphics card, does that mean, that if i change the cards, i ll have to get new blocks as well? (sorry if thats too obvious)
oh and would you be able to tell what kind of temps should i expect from that setup? right now i have titan fenrir and the temps on cpu are 42 idle 76 load
and for gpu 45/49 idle 73/77 load
Not sure on temps but i would be aiming for a higher clock than you have now (4.3Ghz+ )for the same temps. And ya you could get a universal waterblock if you wanted but FC is just easier. Depends how often you change ur cards and if your willing to buy new blocks each time. graphics cards run loads cooler with water. Gurusan has a 4890 under water so he may let you know what temps he gets. Basically expect to be able to push ur rig a lot more with less noise.
