Please Check: Air Cooling Setup
18 Oct 2002
North London, UK
I have just bought a new case for my HTPC and I would appreciate peoples opinions on my selection of air cooling products.
It will be on everyday as a server for our office files and media, it is also going to be connected to a hdtv for Blu-ray and occasional gaming. I might also try some overclocking, depending on heat/noise.
It needs to be as quiet as possible because we have guests staying in the same room as the HTPC and we might need it to be on during the night.
One day I will upgrade the mobo/cpu/mem/gfx, but hopoefully not for a while. I would hope the rest of the components will be compatible.​
Case is the new Silverstone LC10B-E
It has a very similar specification & layout to the GD01, LC17 & LC20 with the following:
Front 2 x 92mm or 80mm fan slots
Rear 2 x 80mm exhaust (included: 2x 2050rpm 21dBA)
Side 1 x 80mm fan slot & PSU vents
This is the list of parts I am considering ordering:
  • 425W Enermax PRO82+ EPR425AWT
  • Thermalright Ultima-90i (with 939 Bolt-Thru-Kit)
  • Arctic Cooling MX-2 High Performance Thermal Compound
  • 3x 80mm Noctua NF-R8 Fan
  • 3x 92mm Noctua NF-B9-1600 Vortex-Control Fan (1 for CPU cooler)
  • Silverstone FP33-S Silver aluminium 3xFanController
  • Zalman VF1000-LED quad heatpipe ATI / Nvidia VGA cooler
  • Zalman ZM-RHS1 Passive VGA RAM (Memory only) Heatsink Kit
  • Zalman ZM-NBF47 Fanless Northbridge Cooler
Is this too much?
Here are my PC components:
MOBO: Asus A8V Deluxe
CPU: AMD Athlon64 X2 4400+ sk939
MEM: 4x 1Gb DDR400 OCZ Platinum XTC Ed. CL2 Memory
HD: 3x Western Digital CAVIAR GP 750GB WD7500AACS 16MB SATA/300
GFX: Radeon HD 3850 512MB AGP8x
OPTICAL: LG GGC-H20L Blu-ray SATA drive
TVCARD: Compro VideoMate Vista T750F Dual DVB-T Hybrid & maybe another Hybrid DVB-T card.
SOUND: Asus Xonar
Thanks for any help.
