Hi,
I'm looking at putting an order in for this build:
My basket at Overclockers UK:
I think this is very similar to a recent thread, but just wanted to check if anybody can see any issues with this? I don't intend to overclock and the system will stay as is for a long while.
Is this case ok? Have been struggling to pick a case and this seemed to be coming up cheaper than a lot of the other cases so not sure if thats a bad thing.
Will this cooler be ok with the CPU at stock?
Thanks
- 1 x OcUK Tech Labs Coffee Lake Pro Gaming Configurator = £2,571.78
- Motherboard:Gigabyte Z390 Aorus Ultra Intel Z390 (Socket 1151) DDR4 ATX Motherboard
- Processor:Intel Core i9-9900K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM
- CPU Cooler:Corsair Hydro Series H100i PRO RGB Performance Liquid Cooler - 240mm
- Memory:Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
- M.2 Solid State Drive **For Operating System If Selected**:Samsung 970 EVO Polaris 500GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive
- Solid State Drive 1:Unwanted
- Solid State Drive 2:Unwanted
- Mechanical Hard Drive 1:Seagate FireCuda SSHD 2TB 7200RPM SATA 6Gb/s 64MB Cache - *System Stock*
- Mechanical Hard Drive 2:Unwanted
- Optical Drive **Please Check Chassis Support**:Unwanted
- Power Supply:Seasonic Focus Plus 850W 80 Plus Platinum Modular Power Supply
- Soundcard:Unwanted
- Network Adapter:Unwanted
- Case Lighting:Unwanted
- Operating System:Microsoft Windows 10 Home Advanced - Systems
- Security Software:Unwanted
- Build Time:Standard Build Systems - Dispatched in approx 7 working days
- Headset:Unwanted
- Keyboard:Unwanted
- Mouse:Unwanted
- Speakers:Unwanted
- Monitor:Unwanted
- Gaming Chair:Unwanted
- Case:Fractal Design Define R6 Midi Tower Case - Black Tempered Glass
- Graphics
alit GeForce RTX 2080 Ti Gaming Pro OC 11264MB GDDR6 PCI-Express Graphics Card
- Graphics 2 (SLI/Crossfire):Unwanted
Total: £2,585.88 (includes shipping: £14.10)
Thanks
