Please check HTPC build specs before purchase from OcUK
2 Mar 2009
Nottingham
Anyone see any major problems with the below? It's for a living room HTPC new build and will also be used for occasional gaming (discrete vid card coming later). Motherboard MUST have HDMI and S/PDIF outputs. Also trying to make sure I have some future-proofing with the 880G board. Always liked Asus boards, but this Gigabyte price seems pretty good.
AMD Athlon II X3 440 £58.99
Gigabyte GA-880GM-UD2H £72.99
4GB Patriot Viper PC3-10666 £70.49
Cheers :D
if it was me, i would go for an Atom330 ION.
the Zotac can be found for £110, so works out abit cheaper, and will handle hi-def and has built in HDMI.
IONs are pretty designed for HTPC's
is there a reason u want to future proof it with a specific board ?
it'll prolly be cheaper and easier, to jsut get a new mobo/cpu when you plan to upgrade it.
but if its just being used as a media pc, then u shouldn't need to.
some of the ION's are also passive, and use very little power, so you can also get a picopsu to make a system that makes no noise
Well, my main plan is for it to playback SD and HD video (stored locally), and perhaps games in the near future. I am looking for a new video card for my main PC, so would be able to hand the 1GB HD4870 DARK KNIGHT down to the HTPC.
Cycrow - you are perhaps right about upgrading in the future with a new board and CPU to be honest, makes sense.
Any ideas as to the cheapest AM3 board with both HDMI & S/PDIF outputs? Am a bit of a sucker for Asus and Gigabyte, and probably would rather stick to those brands.
Why does the board have to have S/PDIF.
Because I will be outputting audio to my Sony Home Cinema amp which has an Optical In. This way, I can be sure of true 5.1 surround sound. I have tested this with my current PC (dayum, it's heavy...) and it worked as I expected.
Problem is not all boards will output DTS and THX signals through the onboard sound, you might be better getting a dedicated sound card if you want the best quality.
dolby 5.1 should be no problem with onboard, and if you amp doesn't do THX then it really doesn't matter anyways.
for the motherboard, i would go with this one
http://www.overclockers.co.uk/showproduct.php?prodid=MB-278-GI&groupid=701&catid=5&subcat=1782
has onboard you can use temporarly until u get a new gpu.
its also microatx, so it can fit into the smaller HTPC cases giving you more choise
Thanks - this is the one in my original post at the top. Never had Gigabyte before, but always thought I'd give 'em a go over Asus if cheaper.
Case is sorted BTW - Silverstone LC13B-E. Could therefore have ATX, but would rather MATX for space at this stage.
