Please check my build :) (GPU and CPU not included)
24 Feb 2025
Cheltenham
Hi,
I'm planing to replace my Xbox Series X. My aim is to play games in 4k 60FPS.
I have already CPU Ryzen 7 7700, and I will consider buying a GPU in March/April. Propably 9070XT/ 9700XTX or RTX 5070TI.
My budget is £700 (excluding GPU and CPU). Should I do any changes? Thanks in advance.
Seasonic Focus GX-1000 ATX 3.1 1000W 80 Gold Modular Power Supply
Quantity : 1
£169.99
WD Black SN850X 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T2X0E)
Quantity : 1
£139.99
Corsair Vengeance RGB EXPO 32GB (2X16GB) DDR5 PC5-48000C30 6000MHz Dual Channel Kit - Black (CMH32GX5M2B6000Z30K)
Quantity : 1
£99.95
Asrock B850 Riptide WiFi (Socket AM5) DDR5 ATX Motherboard
Quantity : 1
£214.99
Thermalright Phantom Spirit 120 SE ARGB Dual Tower CPU Cooler - 120mm
Quantity : 1
£36.95
CORSAIR RS120 ARGB 120mm PWM Black Triple Fan Pack
Quantity : 1
£37.99
Total £707.86 including delivery
That's fine, there are cheaper boards if you don't need the features. You could save a bit by buying Crucial's T500 (is £100, at the moment). I'd be tempted to spend the extra on Antec's HCG Pro (derived from Seasonic's Vertex) if the Focus is £170.
Thank you so much for your answer. Could you please recommend cheaper board? I will check the Antec's HCG Pro.
The Riptide is a pretty good spec board, it has PCI-E 5.0 graphics, a very hefty VRM, 8-layer PCB, higher-end audio, but if you're happy with just functional then anything from the B650 Eagle (£140) and up, is more than fine for a 7700.
What case have you got/getting, do you need the extra fans?
May as well save the £30 and get the Crucial T500.
Could save a bit more going for a 850w PSU, should be plenty for your build.
