- 5 Aug 2006
- Derbyshire
I plan to do the following as my room has big metal beams and the wireless is frequently cutting out:
The switch I plan to use is:
http://www.overclockers.co.uk/showproduct.php?prodid=NW-030-EX
With these sort of cables:
http://www.overclockers.co.uk/showproduct.php?prodid=CB-135-BE&groupid=46&catid=1453&subcat=
Is cat5e the right sort?
The modem router is wireless and has 4 ethernet ports but as the cables are to go up into the roof/loft I want to minimise cabling by using one cable from the modem/router up into the roof, therefore I want a hub/switch up there.
Is what I have drawn in the picture OK?
My networking knowledge is limited.
Thanks
EDIT: Just to check, I do NOT want crossover cables, is this right?
Thanks
