overall load voltage(while stressed,look in cpu-z)
default cpu voltage plus llc plus offset = total load voltage so be carefull howmuch llc and offset you use
its labelled as vccio or its linked to vccsa on some boards so you look for whatever one out of the two is at 1.05v and set to 1.08v for 16gb of memory
OK, so I've had a crack at overclocking my CPU, but I ran into some issues. I started using the offset mode, but even with an offset of +0.5 the IBT failed after 2-3 iterations, running at only 4.0Gzh. (LLC on high)
Then, using manual voltage, I had to use 1.35v to pass a 5-iteration IBT at 4.1 Ghz, and never passed the IBT at 4.3. Temperatures stayed around 80C under load (max recorded was 85C, an only briefly). The voltages changed under load but no amount of fiddling with the LLC seemed to fix that.
So, what am I doing wrong? Or could I just have a really bad chip? Others seem to get 4.3 with around 1.2V, and I couldn't even get it with 1.4V.... the only good thing seems to be that my temperatures are never exceeding 85C, even with 1.4V.
Thank you for your help
