please check my parts
25 Feb 2007
hi lads could some one check these parts for me , my son has picked them out:confused:
are they compatible many thanks
Might want to add a better cpu cooler, a stock intel one just doesnt seem right when there's that much money going into the graphics.
(my new system's going to cost less then them 2 alone!)
2 Nvidia GFX with Intel X38 mobo :confused:
You don't need other parts, i.e. HDD, etc?
I'd get this PSU instead. Don't let the Watts fool you, but excellent piece of kit ;)
EDIT: 4GB RAM needs XP or Vista 64-bit to utilise the full amount.
Don't see why you're going for that expensive RAM, just get two 2x1GB OCZ Reaper kits. Half the price. And X38 I believe doesn't support SLi, so you're screwed there. I think the Corsair HX520W will be much better suited to your system than that PSU.
Others have already explained it but let me clarify. To run 2 graphics cards, you need, obviously, 2 cards & a motherboard which can support them.
If you run 2 ATI graphics cards, this is called CROSSFIRE & you need a crossfire supporting motherboard.
If you run 2 NVidia graphics cards, this is called SLI & you need an SLI - supprting motherboard.
The two standards are not interchangable.
You have 2 NVidia Graphics cards, paired with a CROSSFIRE motherboard. So no, they are not compatible.
If you must run a 2 graphics card setup, then you must either change those 2 NVidia 8800GT graphics cards for 2 ATI 3870 graphics cards, or change the motherboard to an SLI one such as a 680i motherboard.
I'd question whether 2 graphics cards is really good value for money or necessary anyway.
One of those 8800GT's will play almost any game at highest settings at any reasonable resolution & will continue to play new games for some time to come.
If you are not using 2 Graphics cards, then a motherboard based on the P35 chipset (the one you have is X38) will be in every way almost as good for around £80.
I agree on the RAM. There is almost no compelling reason at all to pay more than about £80 for 4GB of decnt RAM.
Overall, this specification contains many good parts but represents poor value for money.
The processor (Q6600) is spot on, probably the best value for money currently available & will last for a long time.
I think the case is a bit expensive & not the best looking but the main thing in a case is if someone likes the way it looks, so if he really wants that one, then go for it.
If you have a large budget, the extra would be much better spent on a nice, large, qulatiy monitor which will make using the whole computer much more pleasurable & last for years to come.
Going by your budget, revised spec...
ATM X38 doesn't offer any performance advantage over P35, just features i.e. PCI-E 2.0, CrossFire, etc some of which are not yet in use :)
