Please check these settings
21 Sep 2008
Please check these setting for me guys i get in to windows then it crashes
Platform
Motherboard Gigabyte GA-EX58-UD5
BIOS f7
CPU Intel i7 920
Cooler Corsair H50
DRAM patriot viper
Advanced CPU Features:
CPU Clock Ratio 20x
Intel(R) Turbo Boost Tech Enabled
CPU Cores Enabled All
CPU Multi Threading Disabled
CPU Enhanced Halt (C1E) Enabled
C3/C6/C7 State Support Disabled
CPU Thermal Monitor Enabled
CPU EIST Function Enabled
Bi-Directional PROCHOT Enabled
Virtualization Technology Enabled
Uncore & QPI Features:
QPI Link Speed 36
Uncore Frequency 17
Isonchronous Frequency Enabled
Advanced Clock Control:
Base Clock (BCLK) Control Enabled
BCLK Frequency (MHz) 191
PCI Express Frequency (MHz) 100
C.I.A.2 [Disabled]
CPU Clock Drive 800mV
PCI Express Clock Drive 900mV
CPU Clock Skew 0ps
IOH Clock Skew 0ps
Advanced DRAM Features:
Performance Enhance Standard
Extreme Memory Profile (X.M.P) Disabled
System Memory Multiplier (SPD) 8.0
DRAM Timing Selectable (SPD) Quick
Channel Interleaving Auto
Rank Interleaving Auto
Channel A + B + C Timing Settings:
CAS Latency Time 8
tRCD 8
tRP 8
tRAS 20
Command Rate 1
All other entries Auto
Advanced Voltage Control:
CPU
Load Line Calibration Enabled
CPU Vcore 1.28750
QPI/VTT Voltage 1.355
CPU PLL AUTO
MCH/ICH
PCIE AUTO
QPI PLL AUTO
IOH Core AUTO ET6 =1.16
ICH I/O AUTO
ICH Core AUTO
DRAM
DRAM Voltage 1.660
DRAM Termination AUTO
Ch-A Data VRef AUTO
Ch-B Data VRef AUTO
Ch-C Data VRef AUTO
Ch-A Address VRef AUTO
Ch-B Address VRef AUTO
Ch-C Address VRef AUTO
Leave most of the settings on auto...
Try this
BLK - 190
DDR3-1520 (Assuming you're running a 1600Mhz setup?)
Uncore 3040
QPI - 6840
Multiplier x21
CPU Voltage 1.28 (MAX 1.35) (Might need rising / lowering)
CPU PLL - Auto (1.80 - 1.96V MAX)
QPI/DRAM - 1.25 (1.2 - 1.35V MAX)
DRAM Bus - 1.65 (Dont go over 1.65, Shouldn't need to)
Leave your Ram on AUTO at the moment, overclock one thing at a time.
Try this
BLK - 190
Uncore 3040
QPI - 6840
Multiplier x21
CPU PLL - Auto
QPI/DRAM - 1.25
DRAM Bus - 1.65
Thanks will try that a bit later just got o go out now but thanks for quick reply.
