Hi Folks,
I am looking to get a new case and a water cooling loop for my main gaming pc.
The spec is currently a E8400 @ 4Ghz, 4GB ram and a 4870 512mb.
I want to get a new case as mine is a bit batter after a few years of upgrades etc but wanted to have a bit of a project over the christmas holidays so want to get a water cooling loop.
This is the spec I have put together.
Reasons for choice
CPU block - good performance and can keep when I eventually upgrade.
Bay res - I am not going to have a window in my case at first so just want something to be able to see the water cooling etc from outside.
Pump - Quiet.
Case - I am going to drill out the rivets on the 3.5" bay drives and put the rad there. It already have the mountings for 2 120mm fans and a front made out of mesh. I'll only need to use the 3 larger bays for 1x bay res, 1 x cd-rw and 1 x hdd in mounting clips.
Also, 140mm top exhaust will be good at removing excess heat
Is this a good setup? I am a bit uncertain on the gain I would get from water cooling temperature wise, my gfx card runs very cool at the mo under an Accelero cooler but my CPU is a bit toasty under a quiet Nocuta.
Thanks
Matt
Reasons for choice
Pump - Quiet.
Thanks
Matt
