Please Check
17 Oct 2006
Aviemore, Cairngorms, Scottish Highlands
Coming over from AMD X2 4600+ is this ok before i click the buy button or can you think of anything better, going to be over clocking it :D
Asus P5B Deluxe (Socket 775) PCI-Express DDR2 Motherboard
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
Tuniq Tower 120 CPU Cooler
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
personally i wouldnt get that mobo
if i was getting a asus one id get the p5w wifi dh dulux one.
not sure how much difference between them is tho ether way that spec is 100% fine tho in reality :)
it will OC good
But yes I agree, with the E6600 and above its best to get a 975X chpset so as stated, a P5W Deluxe will be a good choice
ok thats great will swap the mobo over also looking at
Corsair 2GB Kit (2x1GB) DDR2 PC2-6400 (TWIN2X2048-6400C4D) DOMINATOR
any good :confused:
